12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years ago --- Quote Start --- sorry kaz . i didn't undersatand that .if you remember that distance is output ,i make a signal instead of output but it every clk increment the accum. could you plz illustrate. --- Quote End --- You can have copy of your output before it escapes as internal signal or you can leave it as it is and use a module for summing. either way the signal vout that I posted sometime ago is now handy to indicate a sample is active since output data may stay for many clocks.
