12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years ago --- Quote Start --- when the user write on the keyboard there is a software program capture the data input and measure the trigraphs duration (time) then i will make a sorter to sort those trigraphs duration according thair times ,so i need their time for ordering them only, but trust me i don't know how i give the trigraphs to the fpga . i know the procedures but can't make it reall in fpga board. should you suggest me away to make it?? another guestion my teacher . if i want to sum the distance values and the input may be 100 or 200 or any array i.e not certain number of input .how i can make it --- Quote End --- interfacing with PC is done commonly through nios. If you want a short cut then use realtime editable rams and update them with your new file. for that you need to instantiate rams and activate the realtime edit feature. for adding values of distance use accumulator(just feedback register). for each sum first clear it then sum up in the feedback loop till some 2^n samples so that at the end you truncate n LSBs and clear it for next update.
