12 years agoHow to measure distance between two data
really i have a problem for measure the distance between these data as the following.could i can make it in vhdl from enter this data to vhdl to measure distance between them. d(s1,s2)=(1+1+0+1+1)...
12 years agohi kaz,
i want to thank y very match the design is run correct now the problem was in the simulator program,but now it run perfact . thanks again,you are my vhdl teacher if i want to sum the distance values.i should make distance in a signal then summation those values
