14 years agoHow to make bidirectional bus in SystemVerilog
I have a bidirectional 8 bit bus for communicating between my CPLD and my main CPU. At the top level module I declared this like this (left out details of other IO stuff): module top ( inout [7...
14 years agoYour code is not legal. Apparently the simulator version you are using is not catching the error and producing incorrect results. You cannot connect a variable to an inout port, only wires are allowed to be connected to inout ports. Change the declaration of cpubus in module test to
wire cpubus;Then cpubus will always show the resolved value. Also, there may be a race in your testbench because you change wr and cpubus simultaneously. You should be a delay in your continuous assignments. P.S. You can wrap your code with
your code
and your indentation will be preserved. module top (
inout wire cpldbus,
input bit ale,
input bit rd,
input bit wr,
output reg outbit,
input reg inbit );
logic addr;
logic data;
always_ff @ (posedge ale, posedge wr)
begin
if (ale) addr = cpldbus; // when ale is true latch the address
if (wr)
begin
if (addr == 0) outbit = cpldbus;
if (addr == 1) outbit = cpldbus;
end
end
assign# 1ps cpldbus = (rd) ? data : 8'bZ;
always_ff @ (posedge rd)
begin
if (addr == 2) data = inbit;
if (addr == 3) data = inbit;
end
endmodule
module test ();
localparam time PERIOD = (1.0e9/14.7456e6)*1ns;
wire cpubus;
bit ale;
bit rd;
bit wr;
reg outbit;
reg inbit;
logic data;
// DUT
top u1(
.cpldbus(cpubus),
.ale,
.rd,
.wr,
.outbit,
.inbit
initial
begin
// put some dummy data on inbit
inbit = 8'h33;
// Stimulus
//$stop; // to allow signal setup on wave page
// Write A5 to addr 0
# PERIOD data = 0;
# PERIOD ale = 1;
# PERIOD ale = 0;
# PERIOD data = 8'hA5;
# PERIOD wr = 1;
# PERIOD wr = 0;
// Write 5A to addr 1
# PERIOD data = 1;
# PERIOD ale = 1;
# PERIOD ale = 0;
# PERIOD data = 8'h5A;
# PERIOD wr = 1;
# PERIOD wr = 0;
// Read addr 2
# PERIOD data = 2;
# PERIOD ale = 1;
# PERIOD ale = 0;
# PERIOD rd = 1;
# PERIOD rd = 0;
end
assign# 1ps cpubus = (ale || wr) ? data : 8'bZ;
endmodule
