How to make a custom IP (that integrated with an example design) to create testbench in Arria 10
- 3 years ago
No, the file you put in the simulation files section is the design file that should be used when the design is simulated, not a simulation testbench. This can be the same file as the synthesis file or it could be a different design file optimized for simulation.
Thank you very much for the info.
Also I would like to know is there any Quartus Prime Pro functionality to get a design file optimized for simulation (out of the synthesisable design HDL code) ?
Also you mentioned "different design file optimized for simulation", could you give me an insight of what are those common differences in general cases- Anything coding style or something like that?
I am bit curious that when you asked me about the component editor settings in your first message, is it about the signals and interface settings I used, or the files (synthesis file and simulation file) I used?
Thank you very much
