How to make a custom IP (that integrated with an example design) to create testbench in Arria 10
- 3 years ago
No, the file you put in the simulation files section is the design file that should be used when the design is simulated, not a simulation testbench. This can be the same file as the synthesis file or it could be a different design file optimized for simulation.
Assuming you created this with the Component Editor, did you specify simulation file(s) on the Files tab? If you did not specify separate simulation files (or chose to use the same files for synthesis and simulation), you would encounter this error.
You can refer to this user guide for more information:
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
