12 years agoHow to let FPGA get access to HPS pins
I've got an Arrow SOCkit and it has a USB-UART connected to the HPS' pins, but I'd like to access the UART from the FPGA logic. Is this possible? If so how is it done? Thank you!
10 years agoHi, If I may interfere with the discussion... I'm using the DE0-Nano-SoC Kit, and would like to access both HPS CPS CAN1/2 peripherals. The convenient way looks like attaching my CAN PHY to the FPGA expansion pins. Therefore, I need to route the CAN TX/RX HPS pins to existing FPGA I/O. Can I choose which FPGA PIN with be used? Thank you 😊Ran
