12 years agoHow to let FPGA get access to HPS pins
I've got an Arrow SOCkit and it has a USB-UART connected to the HPS' pins, but I'd like to access the UART from the FPGA logic. Is this possible? If so how is it done? Thank you!
11 years agoThe loan_io_in, loan_io_out and loan_io_oe conduits are all 66 bits wide to allow for all possible loan I/O signals. I'm only using some of the loan I/O signals though, and I'm setting the bits in loan_io_oe to set the loan I/O signals I use to be inputs or outputs as required, and providing a method of driving my loan I/O outputs and reading my loan I/O inputs. I'm confused about what I should do with the bits in loan_io_in, loan_io_out and loan_io_oe that correspond to the loan I/O signals I'm not using though, as these signals are mapped to peripherals instead of loan I/O - what should I set these bits to?
