12 years agoHow to let FPGA get access to HPS pins
I've got an Arrow SOCkit and it has a USB-UART connected to the HPS' pins, but I'd like to access the UART from the FPGA logic. Is this possible? If so how is it done? Thank you!
12 years agoThanks Marcopoliptica.
After hours of trying all these different multiplexing options I have got it working ;) I used to Pin Assignments window to identify the correct GPIO routing for the UART/USB external connector (PIN_B25 and PIN_C25). Both of these are NOT on the loan 61 and 62 but in fact 49 and 50! ... so I used the same LOANIO method and exported 49 and 50 which worked and the fitter assigned them to the desired pins. 61 and 62 would always (correctly) get fitted to PIN_B22 and PIN_G22 respectively, but of course the external connector is physically routed to the above pins. Thanks again for your help, I can now use the external UART/USB with my softcore processor ;) RE the voltage error, yes I later realised I just change them from '2.5 V (default)' to '3.3-V LVTTL' and it compiles.
