12 years agoHow to let FPGA get access to HPS pins
I've got an Arrow SOCkit and it has a USB-UART connected to the HPS' pins, but I'd like to access the UART from the FPGA logic. Is this possible? If so how is it done? Thank you!
12 years agoHi Dez74,
If you want to use LOANIO61/LOANIO62 for UART0, you can set the "UART0 pin multiplexing" to "HPS I/O Set 1" in QSys instead of routing it to the FPGA. Then you can just route to I/O ports in the top file, and during compilation it will automatically set those pins to B25 and C25. As for the error (169026), this is due to the HPS_UART_RX/TX pins being set to 3.3V, while the bank is at 2.5V. In the pin planner, set the I/O Standard of these pins to 2.5V. Marcopoliptica
