15 years agoHow to interface serial Flash (non Altera)?
Dear expert, Does anyone know how to interface with non-Altera external SPI serial Flash (SST25VF016B)? In SOPC builder which interface should I choose? Default SPI or EPCS Serial Flash Contro...
15 years agoI am not specifically familiar with the SST25VF016. Examine the datasheet and compare it with the datasheet for Altera's EPCS devices:
http://www.altera.com/literature/hb/cfg/cyc_c51014.pdf I'm going to assume that you can probably use the EPCS core. This provides you with a software driver for accessing the flash. If you use the SPI core, you are on your own for the software driver. Do you have a board already? If it were me, I'd drop in the EPCS controller and just try it. Jake
