17 years agoHow to interface PC and FPGA through USB 2.0
I want to write a C++ code that will allow for the communication between a USRP board (a hardware device that is used for making Software Defined Radio. It captures the actual data on which modulatio...
17 years agoYour starting point is the driver. Do you already have a software driver for your device? If not then I would recommend using libUSB for windows. The documentation is pretty good and I would expect you'd be able to get up and going reasonably quickly.
Jake
