14 years agoHow to instantiate my SOPC hardware
i'm all new at FPGAs, it's only been a few days since i'm working on it so i started reading some tutorials. I successfully managed to light on a led by using a switch thanks to the tutorial named "Introduction to the Altera SOPC Builder Using Verilog Design". So i wanted to start something a little bit more complicated. I created a new Quartus II project named "project7". Then, i used SOPC Builder to create my hardware, however i really don't know how to instantiate it using verilog. I tried to adapt the file "nios_system_inst.v" from my previous project which was :
// Implements a simple Nios II system for the DE2 board.
// Inputs: SW7−0 are parallel port inputs to the Nios II system
// CLOCK_50 is the system clock
// KEY0 is the active-low system reset
// Outputs: LEDG7−0 are parallel port outputs from the Nios II system
module lights (SW, KEY, CLOCK_50, LEDG);
input SW;
input KEY;
input CLOCK_50;
output LEDG;
// Instantiate the Nios II system module generated by the SOPC Builder:
// nios_system (clk, reset_n, out_port_from_the_LEDs, in_port_to_the_Switches)
nios_system NiosII (CLOCK_50, KEY, LEDG, SW);
endmodule
The file that i wrote is the following :
module nios_system0 (
// 1) global signals:
CLOCK_50,
KEY,
// the_hex0
HEX0,
// the_hex1
HEX1,
// the_hex2
HEX2,
// the_hex3
HEX3,
// the_lcd
LCD_EN,
LCD_RS,
LCD_RW,
LCD_DATA,
// the_leds
LEDG,
// the_switches
SW
input CLOCK_50;
input KEY;
output HEX0;
output HEX1;
output HEX2;
output HEX3;
output LCD_EN;
output LCD_RS;
output LCD_RW;
inout LCD_DATA;
output LEDG;
input SW;
HEX0, HEX1, HEX2, HEX3,
LCD_EN, LCD_RS, LCD_RW, LCD_DATA,
LEDG, SW);
endmodule
However it does not work. Indeed, when i check the pin assignments, i realize that almost none of the pins has been "connected" (because there is a question mark in front of the pin names). I know that i'm not really clear about what i'm saying but i'm all new at FPGAs so it is still a little bit complicated for me :D Some information : I am using a DE2 board with Quartus II 9.0 (web edition) Thank you in advance1 Reply
Try this tutorial:
http://www.alterawiki.com/wiki/using_the_usb-blaster_as_an_sopc/qsys_avalon-mm_master_tutorial There's a DE2 example in there. Cheers, Dave
