14 years agoHow to Implement VHDL Drawing Buffer in DE2
I'm having trouble making a drawing buffer in VHDL on the DE2. I'm currently shooting for 640x480x8x3 bit resolution. In my current implementation I am bit-banging the VGA protocol in a 2...
14 years agoHi,
can't you use a processor such as NIOSII with (important) a bridged access to memory ? if the display takes half of the bandwidth, then the update must be lower than half in practice. It depends if you want to refresh the whole image every time, with a processor, you can simply update the pixels to change. If the whole image needs to be updated, then you just need to arbiter the access and to buffer a streaming update of the memory for example. you have to design it lower than the theoretical bandwidth (memory bank switching overhead), use bursting necessarily. Yes, that sounds like a complicated task for HDL only initiative, maybe SOPC-QSys could be a way out.
