8 years agohow to generate Variable frequancy pwm
Hi, I am trying to write Verilog code to generate pwm signal for step motor controler; The pwm signal frequancy should range from 1Hz to 1MHz,and the frequancy stepper need to be 1Hz. I ...
8 years agoFvM,
The quick reply can not include picture.So I reply sub.
