12 years agoHow to generate .h of all address/ranges in the Qsys "Address Map" Tab?
Hi - I'm working with the GHRD, adding my own designs as ARM Peripherals (and editing the Qsys "Address Map" tab to insert the new devices into the address spaces). It seems like there must be an ea...
12 years agoyes, answer seems to be
$ sopc-create-header-files ghrd_5astfd5k3.sopcinfo thanks /jUser1580871742356367
6 years agowhere to run this command?
from Nios II command shell (gcc4)? Thank you.
