14 years agohow to generate clocks manually in FPGA?
Hi I am programming a module in verilog that use serial input. Because I am using serial input I need a slow clock that i can test my circuit on FPGA device. i heard from on of my friends that...
14 years agoWhen you are bringing asynchronous signals into your design from outside a FPGA, be sure to register the value at least once.
I would suggest registering the input with a clock at least 4x faster than your maximum symbol rate if possible. This should ensure you will find every bit. I would also suggest using clock enables instead of clock dividers. Using these should make the timing behavior easy to work with (so you don't need to worry about crossing clock domains).
