14 years agohow to generate clocks manually in FPGA?
Hi I am programming a module in verilog that use serial input. Because I am using serial input I need a slow clock that i can test my circuit on FPGA device. i heard from on of my friends that...
14 years agoYou can use a counter to generate a slow clock, then drive it through a global buffer to your logic. Basically you use a fast clock, count to some high value (determined by your fast frequency and intended frequency), then toggle a slow clock reg and clear the counter.
You could also use one of the PLLs, or more in cascade. There's tons of examples online for either method. I would say your push button method would not be a good method, because you will need to debounce it anyways (usually with a counter) Edit:Whatever you do don't use a ripple counter as a clock - too much skew
