17 years agoHow to finish the altpciechdma.c driver?
I've downloaded the altpciechdma.c driver for the Altera Arria GX dev kit. The char part of it is not yet finished (due to the comments). And a module is missign "mapper_user_to_sg.h". Smb has...
14 years agoHi Igor.
Thanks for you reply. Here goes the dmesg output: [ 332.548209] altpciechdma exit(), built at Jan 4 2012 11:49:31 [ 339.762209] altpciechdma init(), built at Dec 31 2007 19:54:16 [ 339.762273] probe(dev = 0xf7025800, pciid = 0xf8262cc0) [ 339.762283] probe() ape = 0xef8826c0 [ 339.762290] sizeof(struct ape_chdma_table) = 4096. [ 339.762306] table_virt = ee50a000, table_bus = 0x 2e50a000. [ 339.762336] altpciechdma 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16 [ 339.762360] altpciechdma 0000:01:00.0: setting latency timer to 64 [ 339.762454] altpciechdma 0000:01:00.0: irq 28 for MSI/MSI-X [ 339.762478] Enabled MSI interrupting. [ 339.762581] Using a 64-bit DMA mask. [ 339.762595] IRQ pin# 1 (0=none, 1=INTA#...4=INTD#). [ 339.762605] IRQ line# 11. [ 339.762650] Succesfully requested IRQ# 28 with dev_id 0xef8826c0 [ 339.762661] BAR0 0xd2100000-0xd2100fff flags 0x0012120c [ 339.762669] BAR2 0xfe500000-0xfe507fff flags 0x00020200 [ 339.762727] BAR[0] mapped at 0xf827a000 with length 4096(/4096). [ 339.762759] BAR[2] mapped at 0xf827e000 with length 256(/32768). [ 339.762768] bar_tests(), PAGE_SIZE = 0x1000 [ 339.762776] write_header = 0xf827e000. [ 339.762783] read_header = 0xf827e010. [ 339.762790] &write_header->w3 = 0xf827e00c [ 339.762796] &read_header->w3 = 0xf827e01c [ 339.762802] ape->table_virt = 0xee50a000. [ 339.762828] Allocated cache-coherent DMA buffer (virtual address = ef678000, bus address = 0x000000002f678000). [ 339.762859] writing 0x000400ff to 0xf827e010 [ 339.762868] writing 0x00000000 to 0xf827e014 [ 339.762876] writing 0x2e50a000 to 0xf827e018 [ 339.762883] Flush posted writes [ 339.762888] [ 339.762891] Start DMA read [ 339.762898] writing 0x000000fe to 0xf827e01c [ 339.762906] EPLAST = 64222 [ 339.762911] POLL FOR READ: [ 339.762918] EPLAST = 64222, n = 254 [ 339.763026] EPLAST = 64222, n = 254 [ 339.763136] EPLAST = 64222, n = 254 ... [ 339.773754] EPLAST = 64222, n = 254 [ 339.773870] [ 339.773874] Start DMA write [ 339.773881] POLL FOR WRITE: [ 339.773888] EPLAST = 64222, n = 254 [ 339.773997] EPLAST = 64222, n = 254 [ 339.774108] EPLAST = 64222, n = 254 ... [ 339.784752] EPLAST = 64222, n = 254 [ 339.784867] [ef678000] = 0xef678000 != [ef67a000] = 0xef67a000 ?! [ 339.784879] [ef678004] = 0xef678004 != [ef67a004] = 0xef67a004 ?! [ 339.784890] [ef678008] = 0xef678008 != [ef67a008] = 0xef67a008 ?! [ 339.784901] [ef67800c] = 0xef67800c != [ef67a00c] = 0xef67a00c ?! [ 339.784911] [ef678010] = 0xef678010 != [ef67a010] = 0xef67a010 ?! [ 339.784922] [ef678014] = 0xef678014 != [ef67a014] = 0xef67a014 ?! [ 339.784933] [ef678018] = 0xef678018 != [ef67a018] = 0xef67a018 ?! [ 339.784943] [ef67801c] = 0xef67801c != [ef67a01c] = 0xef67a01c ?! [ 339.784954] [ef678020] = 0xef678020 != [ef67a020] = 0xef67a020 ?! [ 339.784962] ---more errors follow! not printed--- [ 339.784970] DMA loop back test FAILED. [ 339.784983] bar_tests() end, result -1 [ 339.784990] probe() successful. I'm using a Atom processor which is running Ubuntu 10.04 32 bits, and a Altera Arria II GX with the PCI / Chaining DMA example synthesized on Quartus 11.1. I've been around this for some days now, so any suggestion would be greatly appreciated. Best regards, Pedro
