9 years agoHow to find out a Tco from TimeQuest
Hi all! I'm using Quartus TQ and I have a question about the best way to measure a Tco for a FPGA pin to pin. My task is specifically for the case in that example - https://www.altera.com/conte...
9 years ago --- Quote Start --- As also stated in that doc you linked to: tCO is meant to be time from clock edge at clock pin input (that clocks the output register) to data transition at output pin of that register(if its input changes). You don't need to sum up clock cycles on any other registers (that is latency) tCO is not used for combinatorial paths. It = clock delay from pin to register + register micro tCO + register to pin delay So I do feel it is what you are after. --- Quote End --- Hi kaz! Yes, exactly, as about tCO parameter it is what you wrote. I was interested if there is such parameter that sum tCO and integrated clock cycles on other register (a path from input pin to output pin with intermediate registers inside the path).
