12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years ago --- Quote Start --- let say now i set the threshold as 1000000, and above this value, the peak values and their locations will be outputted in a single waveform as shown in the attached picture, and how to save each peak value and location in different registers for me to do further calculations? --- Quote End --- run a counter enabled only when a peak occurs. so you then save peak0 at count0 into reg[0] then save peak1 at count1 into reg[1] and so on.
