12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years agookok... i understood this... but i need the waveform show only the largest value without showing the previous smaller values... never mind, i try to find solution myself... thanks so much anyway :)
