12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years agoJust use my above code. The max_val updates and stores din by itself until it is updated (if at all).
I am sorry I have not done verilog for years so can't help directly at code level. Yourlast code and waveforms looks ok to me
