12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years ago --- Quote Start --- What another way? It is same one I am telling you since last year!! and your code : why do you keep using the wrong signal name: why do you use max_val_tmp, I did not say that. --- Quote End --- last year?? i just joined today... if i didn't create a temparory reg "max_val_tmp" how can keep the number for comparing with the next number?? if you don't mind to edit my whole codes, so i don't make any mistakes again won't ask you anymore??
