12 years agoHow to find largest value and its position in memory array?
As attachment... the memory array contains continuous input at every positive edge clock... these inputs are the outputs from the Altera FFT core... then i need to find the peak and its location... p...
12 years ago --- Quote Start --- Thank you Kaz for your time :) **p.s. I need to write d_in into mem_array[Q] so that i can keep track on its location right? **another way i found something: "develop a verilog model for a peak detector that finds the maximum value in a sequence of 10-bit unsigned integers. a new number arrives at the input during a clock cycle when the data_en input is 1. if the new number is greater than the previously stored maximum value, the maximum value is updated with the new number; otherwise, it is unchanged. the stored maximum value is cleared to zero when the reset control input is 1. both data_en and reset are synchronous control inputs." --- Quote End --- What another way? It is same one I am telling you since last year!! and your code : why do you keep using the wrong signal name: why do you use max_val_tmp, I did not say that.
