12 years agoHow to export FIFO_OUT_CSR outside QSYS?
Hi, I have some Fifos inside Qsys system and I would like to export the FIFO_OUT_CSR to logic outside Qsys, using a Conduit Interface (PIO Parallel IO). However, the OUT_CSR is a Avalon Slave I...
12 years agoyou'll need to export the MM Slave interface directly and drive it with an MM Master state machine, or maybe add a NIOS, read from the CSR and write to the PIO
