CosmoKramer
3 years agoHow to execute sdc command before starting compilation in order to check syntax?
How can I verify if the syntax of sdc constraints is correct before starting compilation? I tried to execute sdc constraint from tcl console in the gui but got an error that sdc commands are part o...
Nurina
3 years agoHi,
I'm not exactly sure what it means. I don't see any mistakes in that.
Since you have run fitter, I would save all the SDC constraints in an SDC file, then run it on Timing Analyzer. Steps available here: https://www.intel.com/content/www/us/en/docs/programmable/683068/18-1/step-4-run-timing-analysis.html
Then after you have run timing analysis, I suggest to report ignored constraints, this would report the constraints that are ignored possibly due to wrong syntax, or missing targets. So from here you have a clue of which constraints you should fix.
Nurina
