CosmoKramer
3 years agoHow to execute sdc command before starting compilation in order to check syntax?
How can I verify if the syntax of sdc constraints is correct before starting compilation? I tried to execute sdc constraint from tcl console in the gui but got an error that sdc commands are part o...
Nurina
3 years agoHi,
Just found a different way which I think you might like-
On Quartus GUI, create a new sdc file. On the editor you can right click and select "Insert Constraint" and this would guide you to correctly write an SDC constraint.
Nurina
