14 years ago
how to draw a line on vga ?
how to draw a line between two point on VGA ( verilog code ) . when i click two point by mouse (ps2) on vga , it will auto connect between two .
please give me your idea . thanks!
    --- Quote Start ---
    Does it "HAS" to be in Verilog only ? No C, no NIOS-II ?
    are you using some terasic boards ?
    In that case I would recommend using the NIOS_HOST_MOUSE_VGA project, I didn't work on project, but I expect it to be easier than going through Verilog.
    --- Quote End ---
    right ! use NIos easier than . but in my project only allowed use verilog , :( thanks for your comments ... if you have document about it , please share with me :
    --- Quote Start ---
    The common way is to draw on memory then display with a VGA from mem IP.
    Yet, you can draw directly with X,Y counters of the VGA output and conditioning the output:
    if(X == 5)RGBOut = color1;
    if(Y == 10)RGBOut = color2;
    and it gets more complicated for diagonals that would need raterisation.
    --- Quote End ---
    thanks you so much ! but , i have edited my answer ..... please
