YYang79
5 years agohow to download user code to the flash memories on cyclone 10GX development kit
How can I load user pof file to configuration EPCQL(U4) as well as to the two CFI memories(U42,U43) on the Cyclone 10GX development kit?
I have not found any info about how to do these in the...
NurAiman_M_Intel
5 years agoHi,
Please share the screenshot of the error and Switch S1 that was used.
What Quartus version was used?
Aiman
- YYang795 years ago
Hi Aiman,
I am using Quartus prime pro. 17.1.
S1 is set to "11". For AS configuration, it needs SFL ip to support programing of the on board EPCQL1024,doesn't it?
Attached please find out the screen shot for the programing process.
- NurAiman_M_Intel5 years ago
Upon checking the error, in the link below,
it mention:
CAUSE: You used the Programmer with one or more programming option(s) turned on. However, the Programmer did not successfully perform the operation(s). This problem can be caused by one of the following situations:- Communications cables not securely connected
- Incorrect device selected
- No power to target system
ACTION: Make sure all cables are securely connected, select a different device, or check the power on the target system.
The reason might be due to the photos below, try to delete the red box in the photo below and start to program again.
Aiman
Hi Aiman,
It still fails. See attached. Thanks.
