YYang79
5 years agohow to download user code to the flash memories on cyclone 10GX development kit
How can I load user pof file to configuration EPCQL(U4) as well as to the two CFI memories(U42,U43) on the Cyclone 10GX development kit?
I have not found any info about how to do these in the...
NurAiman_M_Intel
5 years agoHi,
Apologize for the delay in response as I was checking this with my team.
At the back of the board, there are default switch setting (MSEL setting pin). Hence you need to manually set the MSEL pin at the physical board as AS and program the board as AS. Kindly follow the switch setting in the userguide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-c10-lp-eval-kit.pdf
Aiman
- YYang795 years ago
Yes, Aiman, I selected S1 switch to "11" for EPCQL downloading. It fails to allow me program it. Is the board something wrong or is there any other setting that is not mentioned in the manual?
