how to download user code to the flash memories on cyclone 10GX development kit
If you are using Passive Serial(PS) sorry to tell you that it is not supported for EPCQL. You will need to use other device that supported PS. CFI is for PS.
If you are using Active Serial, kindly select AS mode and convert .sof file to .jic (select AS mode and device accordingly). EPCQL only supported AS mode configuration.
Thank you.
Aiman
- YYang795 years ago
Hi Aiman,
Thank you for your response.
I think you were misunderstood what I talked about CFI chips on the development board.
If you open the BTS to EPCQ tab, you will find the picture on the left indicates the location to "EPCQ", but unfortunately they are two CFI chips there,U42 and U43. They are MT28EW01GABA1LPC-0SITES. It looks wrong. It is not the location of EPCQ chip.
Based on the manual, on this development kit board there are two ways in which we can configure the C10, one is AS by an EPCQ-L on the board which is U4, if using this way i should program the fpga with SFL ip first and then download my code in jic to the EPCQ chip. I tried but failed i don't know why? Another way is using FPP over the PFL in a MAX10. I converted my sof file into CFI 2Gb pof file to load the two CFI memory chip it failed too. I have no idea why.
Please confirm what i say above.
I am a little bit frustrated with this board. Lots of uncertainties and ambiguous statements. This is my first time dealing with Cyclone 10. I do need your help please.
Appreciate a lot.
