SSenn
7 years agoHow to describe a process with asynchronous reset in VHDL for the ARRIA 10 FPGA
Hello, i have some trouble with the reset signal. I use VHDL to describe my logic. The target FPGA is an ARRIA 10. I have realized that the reset signal is connected as a global enable signal (ENA)...
- 7 years ago
If you put s_data <= data; in the if-else condition, the data will be controlled by arst_n = '0'.
SSenn
7 years agoHello YY
Everything is fine if I describe the logic in two processes. Than no clock enbales are synthesized.
But I was hoping somebody would have a better solution. When the logic becomes more complex (this logic is a very simple example), the description with two processes can be hard for other developers to read/understand.
