Hi @patrickk
Updating you on my findings.
1) LVDS SERDES IP does not support x2 (DDR), to do so you need to use GPIO IP.
2) The datasheet footnote 66 is suggesting that there could be signal integrity or board skews that could cap the maximum frequency.
3) From (2), even if you have a perfect signal integrity, the maximum frequency you can achieve is 300MHz (as what the Quartus indicated).
4) I tried to check for alternative using the XCVR, but XCVR does not support DDR and XCVR has other limitations with it as well (coupling, run length, etc), which may further complicate things.
Thank you for researching the DDR receiver design for the Stratix 10 FPGA. It is good to know that I need to stay with the GPIO IP and limit DDR transfer speed to 300MHz, best case.
I discussed this with our System Engineer, and he will adjust the system requirements for the lower speed. I will work on the design and see what throughput can be achieved.
