How to control rising/falling time, sampling time of GXE Transceiver?
As I understand it, it has been some time since I last heard from you. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
I want to combine transmitter with receiver, and need to control transmitter output with high-Z when some data is being received. how to make transmitter with high-Z? this is my fist question.
the second qustion is how to control the timing of driving and receiving on tranceivers by myself.
Thanks a lot.
- jhong285 years ago
I got additional information in the user manual " ug_etile_xcvr_phy ".
I have questions on table 13.
I wnat to use a tranceiver on Duplex mode, but dependently, which means if receiver enable, trasmitter and Ouput disable, and some time later if transmitter and enabled, receiver disabled.
if i change attribute data from 0x0002 to 0x0005, is that correct?
After changing attribute data, any training is needed?
Thans a lot.
