13 years ago
how to connect analog input directly to FPGA Altera board?
hi;
I want to implement Sigma Delta ADC on Altera DE1, i wrote the code and run on QuartusII; now i want to know
is it possible to connect the analog input directly to the board?
as in my code the input is introduced as signed [7:0] so my original analog input should be converted to the type signed [7:0] before enter the altera cycloneII core is this conversion possible on the board?
at the end how can i get my digital output from the board and analyze it?
your guidance is very appreciated.
thank you
    thanks linas..
    you mean i need an off-chip ADC to capture my analog signal signal to FPGA? so any ADC suggested for this effort?
    You need an additional analog to digital converter to capture your analog signal to FPGA. Perhaps you should implement some module in VHDL/Verilog to emulate your analog input? You can analyze your design with Altera's Signal Tap or send the values of interest to PC via RS232 as more advanced option.
