16 years agoHow to connect a peripheral with "waitrequest" signal to the AVALON MM BUS?
I had a piggyback-board with 16K/16bits SRAM interface and a "waitrequest" signal, normal avalon mm-tri slave port can not support "waitrequest" signal, so how can i interface this board to the NIOS ...
16 years agoIs your peripheral shared with other peripherals on the tri-state bus? If not, you can create your own custom interface and create a regular Avalon MM slave rather than using the tri-state slave.
Jake
