ZLu001
7 years agohow to configure Cyclone V and EPCS64
I asked this question before, so far no solution. I'll try to repeat the question and describe my recent effort on it and seek help. 1. My connection is exactly as figure1. 2. The connections...
AnandRaj_S_Intel
7 years agoHi,
Since you can program sof file successfully.
This may be because of configuration file or signal integrity related issues. You can try to monitoring the flash and jtag signals which will help to find the exact cause of the problem.
- Can you please check if the Flash part number in schematic, hardware are same.Also use correct flash device while converting .sof to .jic.
- Delete the db, increment db and output folder and run full compilation.
- While programming .jic, use jtag header and jtag mode.
- Try to change the tck frequency and check.
Anand
