18 years agoHow to config MAXII with MCU
Hello everyone
Recently I want to config MaxII with MCU ,so can you give me some suggestion? Thanks may be Jamplayer?or ?3 Replies
I don't understand what you searching for. You have been talking of configuring from a MCU not from a PC. What is the role of NT with your MCU?
you say JRunner ,but it can used in windows NT
Embedded JRunner should be a solution. Cause MAX II has flash configuration storage with limited number of reprogramming cycles, it must be programmed only in case of configuration updates.
