10 years agoHow to close timing with Negative Setup Slack
Hi, I am working on a hardware design working at a clock frequency of 200MHz(5 nsec). Setup violation of -0.265 ns is reported by quartus tool. The source clock and the destination clock are sa...
10 years agoOk, got it. From looking at the timing report it appears there is 9b adder that feeds into a 12b adder, and both are ripple carry implementations.
What you need to do is coerce Quartus to synthesize faster carry lookahead adders that (ideally) use the capabilities of the logic cells in the FPGA. I found this app note: https://www.altera.com/support/support-resources/design-examples/design-software/vhdl/v_cl_addr.html but it refers to a much older version of the software and an older architecture. However, setting the tool to do more aggressive synthesis/optimization may still work.
