10 years agoHow to close timing with Negative Setup Slack
Hi, I am working on a hardware design working at a clock frequency of 200MHz(5 nsec). Setup violation of -0.265 ns is reported by quartus tool. The source clock and the destination clock are sa...
10 years agoHi ak6dn, Thanks for the quick reply.
So the ripple carry is the result of synthesized hardware, as interpreted by synthesizer. Its a parallel 256 sized combinational logic, which got translated to ripple carry adder, and the critical path includes most of the adders, and hence lead to a negative slack of -0.265 nsec. The next timing slack is also negative, but negligibly small (~ 5ps). Regarding cutting down the combo delay with pipelined registers, The main objective of the my low latency hardware is to bring down the latency as far as possible, and hence I m trying to see angles, other than cutting down combo path(Since the negative slack is less than 1ns). Yes, assuming, I m making the hardware work at ambient conditions at nominal voltages, Can I expect reliable operation ?. Any other suggestions?. Regards Jeebu
