16 years agoHow to check if the onchip_mem is full?
I'm running AN429 sample code (VIP core) on my 3C120 evaluation board. I add button pio to the SOPC which already have VIP core inside. Quartus can generate ptf ok. However, when I try to build the c...
16 years agoAll you can do is look at the size of your compiled ELF file. This information is given to you at the end of a successful build. You can also open a nios2 command line console at any time and use the "nios2-elf-size" command on your compiled elf file to see how large it is. This of course does not take stack and heap considerations into account.
Jake
