14 years agoHow to check clocks using SignalTap II Logic Analyzer?
Hi all, I am learning how to use Signaltap II logic analyzer using this tutorial: http://www.altera.com/literature/hb/qts/qts_qii53009.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=design%20debugging%20...
14 years ago --- Quote Start --- I use another clock for sampling in signaltap II is 576 MHz. --- Quote End --- Ok, so you should see something that looks like a square wave then. --- Quote Start --- I did this because first, I want to see if the period and the shape of the two clocks look similar in terms of visualization (normal eyes). --- Quote End --- You won't see that with SignalTap. You need a scope for that sort of visualization. --- Quote Start --- And the fact that they looked totally different makes me believe that there exist some problem. And I don't know where it can come from. Do you have an idea? --- Quote End --- Look at the clock output with an oscilloscope. Look at the schematic. Is the SMA output clock direct from an FPGA pin or does it have a series termination resistor? Is the SMA input clock direct to an FPGA pin or does it have a buffer between the SMA and the FPGA or does it have a termination resistor? Is it AC coupled or DC coupled? Have you terminated the transmission line correctly, eg., enable a parallel termination if an external one does not exist? That's a few things for you to think about. Cheers, Dave
