10 years agoHow to add several of the same IPs (UARTs) to Qsys automatically?
Hi all, In another thread I asked if there was a limitation on the number of components (IP) in Qsys and I was told there was not. So now I created a test project to see how many UARTs I cou...
10 years ago --- Quote Start --- You won't be able to fit 100 uarts in a CPLD. Depending on what your needs are, you might be better off with something like a Cyclone V FPGA. --- Quote End --- MAX 10 has up to 50K LE and I believe a UART uses less than 200. So there is quite a bit of capability before you need a Cyclone.
