16 years agoHow to accumulate variable using submodule
I am trying to model an equation of the type: x=bx+c in Verilog. I've written a module which takes input 'x' and gives output 'bx+c'. However since the input and output out of a submodule hav...
16 years ago --- Quote Start --- I am trying to model an equation of the type: x=bx+c in Verilog. I've written a module which takes input 'x' and gives output 'bx+c'. However since the input and output out of a submodule have to be nets(wires), this is how I'm trying to model the equation: Let's say the submodule for 'bx+c' is 'submod1' I've given the names: xin--> Input net to submod1 xout-->Output net from submod1 xreg-->A register in top-module for storing and reading values from submod1 always @(xout) begin case(rst) //rst, reset signal for resetting the value to 0 1'b0:if(xout!=32'hx) //Copy xout to xreg only if the signal is stable xreg=xout; else xreg=0; 1'b1:xreg=0; endcase end assign xin=xreg; Can anyone see any problems with this code? Any help is most appreciated. --- Quote End --- Hi, I would make the design synchronous ( use a clock). Have a look to: // x=b*x+c module test (reset, clk, b,c, out); input reset,clk; input [1:0] b,c; output [3:0] out; reg [3:0] result; always @(posedge clk) begin if(reset) result <= 0; else result <= result * b + c; end assign out = result; endmodule It is only a simple example. You have to take care about the required output width and the handling of signed numbers if required. Kind regards GPK
