10 years agoHow to access to license server via proxy?
My environment needs to access network via a proxy server. I configured the proxy server in the Quartus option configuration that is "Tools" -> "Options" -> "Internet Connectivity" -> "Access the web...
10 years ago --- Quote Start --- Only solution : If you can access directly and cannot connect cause your behind the firewall perhaps it will be worth to use myAltera support. cause it depends on how your network is organized. --- Quote End --- OK, I will try myAltera support. Thanks.
