13 years agohow the data is transfered using PCIE LINK
I am using the altera S2GX for a project uses PCIE to transfer data. Now we have the hardware working with the PC, since altera didn't provide the source code for the pc app. I am not sure...
13 years agoThe basic problem is that although PCIe is high bandwidth, it is also high latency.
So if a cpu tries to read a location over PCIe the instruction will stall for a long time - probably in the order of 10us (think ISA bus speeds). This is the same for an x86 host reading fpga memory, or a nios cpu reading host memory. Writes can be a little faster since they can be 'posted' (address + data latched and the initiating cycle terminated). This is not too bad for diagnostics, but horrid for anything that requires any amount of throughput.
