XQSHEN
4 years agoHow set timing constraint for such clock
In my design, the spi clock to external device was divided by counter.
if use below to set timing constraint, it reports below warning:
Node: nios:nios_0|mcu_uadc:mcu_uadc_0|read_cnt[2] was deter...
- 4 years ago
First, I would make uadc_sclk be a reg variable and not a wire.
Then, you have to add timing constraints for your derived clocks. For example, I have this in my .sdc file for a design:
# Input 50MHz reference clock create_clock -period 20.0 -name CLOCK_50 [get_ports {CLOCK_50}] # Created clocks based on PLLs (CPUCLK = 80MHz) create_generated_clock -source {pll|altpll_component|pll|inclk[0]} -divide_by 5 -multiply_by 8 -duty_cycle 50 -name CPUCLK {pll|altpll_component|pll|clk[0]} # Created clocks based on logic (RTCCLK = 25KHz) create_generated_clock -source {pll|altpll_component|pll|clk[0]} -divide_by 5000 -duty_cycle 50 -name RTCCLK {dk8ea_clock:rtc|rtcclk}where the clock RTCCLK is generated via this code:
// system clock divider to RTC clock rate reg rtcclk; // rtc clock reg [31:0] rtcdiv; // rtc prescale clock divisor always @(posedge clk) begin if (reset) begin rtcdiv <= #TPD 32'd0; rtcclk <= #TPD 1'b0; end else begin rtcdiv <= #TPD (rtcdiv == PRESCALE-1'd1) ? 32'd0 : rtcdiv+1'd1; if (rtcdiv == 32'd1) rtcclk <= #TPD ~rtcclk; end end
ak6dn
4 years agoWhat is your question? I do not understand what you are asking.
