13 years agoHow LEs are aligned
Hello I have three questions considering about how LEs are aligned and placed. (1) I want to know how LEs are aligned "physically." Because by the default of Quartus II LEs are sometim...
13 years agoThere isn't a single solution. Of course having the LE right next to the I/O pin is the best solution and it looks better, but as far as Quartus is concerned, having it at the other side of the FPGA is also an acceptable solution if the delay between the LE and the I/O pin is under the limit that you set in your timing requirements.
You might be interested in this very good document (http://www.alterawiki.com/wiki/the_quartus_ii_fitter_and_seed_sweeps) from Rysc that explains a bit how the fitter algorithm works and why it looks like it is random.
