MSheh4
6 years agoHow I can use a particular PLL in Cyclone 10LP?
Hi, I am using Cyclone 10LP in my design and I want to use PLL3 instead of PLL1, by default the compiler selects the PLL1. This is an existing design which uses FPGA cyclone III and the software ve...
Rahul_S_Intel1
6 years agoHi ,
Really apology for been in late reply, some internal tool issue was there to assign your case to me.
From your question , what I understood is when you change the pll in Quartus design for Cyclone 10 LP , quaruts is giving the compilation Error . And the PCB is already manufactured by assuming a different PLL.
if the case is above , may I request to instantiate clock control block and assign the clock to global and can you give to PLL .
